So in this case I will just order another one to see how much life I can get out of it milling only wood… maybe aluminum too. I’ll still keep the burnt bit as a talking piece :).
Bits - From the depot or lowes or even the lower amazon action if it colors toss… I personally wing it and when I am worried about finish will get a new bit no problem if it is a project that matters. Testing I keep the bits that may not be amazing but still work. I also have a yonko compression 4 flute that I use sparingly - and a special 3" long unit for the good deep stuff… Amana Tools for the tapered ball nose tn coated specialty action…
whatever you do just get yourself on the track on buying quality bits as there are a bunch of cheap ones out there but eventually you will always spend more on those and want a quality tool they are just designed different and its the little touches that count in end mill tooling quality
Here is a document that I use sometimes to record parameters!!
CAUTION THESE FEEDS AND SPEEDS ARE FOR MY BIG 4X8 FT MACHINE WITH A PROPER SPINDLE THIS IS NOT FOR THE X-CARVE ALSO THE DOCUMENT IS KINDA OUTDATED BUT WILL GIVE YOU AN IDEA ON HOW TO RECORD THINGS
Nice, I was figuring. Was more interested to find out what you’re running. In the nearish future, I’m thinking about building a stronger machine and switching the xcarve out to a laser also.
oh yeah I like the machine but I hate it at the same time lol
make sure you get a spindle and dont use a router it will be night and day difference when cutting
and I really really really really really!!! wish the machine had a vacuum table
(I am designing one for it currently)
but for the work that I do I really need one
and I really really really really really!!! wish the machine had a automatic tool changer
but I didnt know what i needed when I bought it lol so all those things are my fault
other than that the machine has been alright if you can afford just a little more I would defiantly recommend a laguna or shop bot over the cncrp machine because it has more features that you really need
