1/8'' 60 degree bit
I did alot of searching on how to input the 1/8’’ inch 60 degree bit in easel and not sure if I can use it in ‘others’ of the end mill section or if I use the V-bit section. Also I’m pretty sure it goes under other’s but not sure what width to put in.
Any help would be appreciated, thx!
I assume you mean 1/8” shank. If so, you should be able to just select the 60 degree v bit.
no, I mean the 1/8’’ shank, sold by inventables under v carving
oops sry misread it, thx
:joy::joy::joy:
