1000mm work area rail kit?
So I just ordered the 1000mm X-carve minus the waste board kit thinking I could get it locally and I’ll just purchase the hardware from you guys.
This is not as straight forward as I thought
I looked around the forum and found different part numbers needed but some part numbers do not exist leaving me wondering.
I selected 1000mm rail kit option during purchase, does this encompass the needed rails for the waste board?
On the order page its list that waste board kit consist of :
1000mm Waste Board Kit - [Add $128.00]
Waste board with threaded inserts and hardware (clamps not included)
But on the Assembly pages It seems that I would need a rail kit not only for the waste board but for connecting the drag chain. Did I already purchase the needed rails or not is my question?
Thanks!
+++++from the assembly page++++++
1000mm Work Area
1000mm Waste Board Kit**
SKU Name Quantity
30537-01 Waste Board 1000mm 1
30517-03 Threaded Insert M5 144
25286-20 Button Head Cap Screw M5 x 20mm 14
25281-05 T-Slot Nut M5 Pre-Assembly (Insertion Nut) 14
1000mm Rail Kit
SKU Name Quantity
26049-02 Aluminum Extrusion 20mm x 20mm Black 1000mm Lg 2
26049-04 Aluminum Extrusion 20mm x 20mm Black 958mm Lg 3
26018-01 Extrusion Bracket (Gusset) 6
25286-18 Button Head Cap Screw M5 x 10mm 12
25281-05 T-Slot Nut M5 Pre-Assembly 12
Everything is included for the waste board in the rail kit. This was fixed due to everyone wanting to make their own waste boards
i ordered all the extra parts separately when i ordered my x carve minus waste board. are you sure about everything being included now? i was charged for the extra parts… but i guess maybe they just changed the pricing of the rails to reflect the difference?
Ah, by “everything”, I believe he is meaning that the support extrusions are included as well. I am reasonably sure you still need to buy the hardware to make the board, the threaded inserts and soforth. :smile:
Good read I don’t have to purchase more rails!
Here is the e-mail I got from CS:
If you plan to make your own Waste Board we have put together the following information for your review.
  1. The engineering files for the 1000mm board (A Fond Farewell to GrabCAD Workbench - GrabCAD Blog) and silk screen file (A Fond Farewell to GrabCAD Workbench - GrabCAD Blog)
  2. You’ll also need the hardware that comes in the kit
a. 144 threaded inserts, 2 bags of part #30517-01 (Threaded Inserts – Inventables, Inc.)
b. 14 pre assembly insertion nuts, 2 bags of part#25281-02 (http://bit.ly/1J2ORGF)
c. 14 Button Head Screws M5 x 20, 2 bags of part #25286-15 (Button Head Cap Screw – Inventables, Inc.)
Samantha Jo Alaimo
Customer Success Specialist
Inventables
