Just learning. Purchased an STL File and get this error when generating tool paths.
https://easel.inventables.com/projects/KCd5ICZjBYu7HUwSx5roUg
Hi, before people can help you’ll need to make your project shareable. See @SethCNC’s instructions for this here HOW TO SHARE your Easel CNC Project with a SHARE LINK - YouTube
completed. thanks.
Your end mill choices are to large for this type of carve. Change the roughing end mill to the following:
For this carve, which is similar in size, I roughed with a 1/16 bit and then used a taper bit with a manual setting equivalent to a 1/32 or approximately .03:
Eric,
Great job!!
FYI: That carve line you have is a pause line. another way of putting it, a long carve put on pause and continued latter.
Happy carving
Thank you Ken. I’m still learning and can always do it better. I just wish I didn’t have to make so many mistakes to figure things out.
Eric,
last time I checked, mistakes are a form of learning
happy carving
Thanks for the help. I will give this a go.
Glenn,
To get some help, you’ll need to share your project.
Here’s some instructions on how to do this from @SethCNC HOW TO SHARE your Easel CNC Project with a SHARE LINK - YouTube
[/quote]
