We use cookies to personalize content, interact with our analytics companies, advertising networks and cooperatives, and demographic companies, provide social media features, and to analyze our traffic. Our social media, advertising and analytics partners may combine it with other information that youāve provided to them or that theyāve collected from your use of their services. Learn more.
Did you mean to say that the gShield x axis driver is working and the Y axis driver is working? Because when hooking it up to the Y to the x-axis on the gshield the machine moved in the Y direction whereas the Y axis driver did not move in the x direction.
When I disconnected I disconnected the 4 wires on the right side if you were facing the machine. I did however reconnect them prior to the test so both of the Y motors are confirmed working.
Your response said that, with the change, the X axis worked but the Y axis didnāt.
So, what you had was the Y axis (machine) hooked to the X axis (gShield) which would indicate that the problem didnāt move when you reversed the wires.
If the problem moved from the Y axis (machine) to the X axis (machine) then that would indicate a bad Y driver chip on the gShield.
