New here. Can i set a fine detail bit to shallow level and the rough cut to full depth. I am wanting to trace a figure and do fine cut on path, then use a larger bit to cut thru 3/4 inch width of wood.
Hi. I’m new to the community and running into same problem on my first project. Is there a different solution to it beside setting different work piece?
At the current time, there is not a different solution, the multiple workpieces is the only available method.
I’ve heard that they are working on a different, better method, however that is not more than rumor mill at this time.
Thank you
