2 pass carve
Good day, is there a way to have Easel Pro repeat a carve to clean any unshaven material? I am using acrylic 2 color and find I need to run the job twice to clean it better. i would rather set as a single job if possible. Thanks
No way that Iā€™m aware of.
You can cheat by depth per pass vs full depth so it dont add up to even numbers.
Say I want ro cut 2mm acrylic and want a clean-up pass:
Set depth per pass to 0.99mm, so 2nd pass is at 1.98mm, you now have a third pass taking only 0.02mm.
(Note that Easel my round up some numbers so dont take my arbitrary numbers as absolute truth)
Great thanks. Will give it a try.
