2024-newbie with X-Carve
Hello community! I bought a CNC a little over two years ago. But I never had the time to build the machine. I started last November. I just started testing and already I see that the x and y axes do not move when I activate the Home command. I checked all the wiring and contacts, I changed lines of code as suggested in the forum. The tests to move the axes are positive but nothing move. I also managed to configure the Z Probe even if I do not understand what it is for. (For the zéro point?) It’s a bit frustrating, I’m really looking forward to starting using it. I have read everything I could find on the subject without being able to correct the situation. If anyone has also had the same problem, I would appreciate a little troubleshooting. Thanks in advance.
[/quote]
Check to see if all the wiring is correct. Go through the Easel set up portion of assembly as that will allow you to test your motors and directions. The Z probe is a device that allows you to set the depth of your bit accurately. You can also do it mechanically by jogging the z axis down until the bit contacts a piece of paper on top of your material and then zeroing it out.
Assuming you have an x xcontroller, make sure the emergency stop is pulled upwards and not engaged.
Home switches involve a grbl setting change. This will be made by going through the set up and answering the questions. It can also be done manually by typing $$ in the command line and typing the change into the setting.
X-Controller | X-Carve Assembly
CNC How-To - Setting up Easel for the first time (Machine Setup)
This describes what each setting does:
GRBL_Settings_Pocket_Guide_Rev_B.pdf
$22 is the homing cycle. 0 is enable 1 is disable
[quote=“MartinW.Mcclary, post:2, topic:159328”]
Thanks Martin for your prompt reply.
-Wiring is correct;
-Testing motors and directions done with Easel , all directions move well but not the homing for X and Y;
  • I have an X-controller and the emergency stop is pull up;
  • All of the grbl settings are checked and have benne changed if necessary;
I will do again all the processus this afternoon. :christmas_tree:
After re-inspection of the connections, there is no indication that the wires are broken or that the connectors are not properly connected. I do not understand what is wrong. I decided to test the machine without using “homing” and everything is fine. My problem is not solved but I can still move forward in my understanding of how to use the X-Carve. Happy New Year 2025!
