Warning …
New Easel firmware turns your on screen stop stop button but into a full out E-STOP. It will no longer return you to work zero. I need that go back to the old firmware somehow . Waiting for it to rehome is HOT FIRE GARBAGE!
Which firmware is this? I sure don’t want to upgrade to this for sure
Its the beta. They sent a note theyre working on it.
Hi @ZackHall,
Thank you for letting us know about the problem you encountered. We have updated Easel to support the flow you mentioned.
You don’t have to do anything outside of using new firmware. Next time you load Easel using Spindle Pause Firmware, you will be able to stop the carve without losing your work zero.
Thanks,
Kacper
