Mr. Charlie I have the triquetra hooked up now on the new double extra-large table and it probes perfectly for the three access yet however when I just try to Z access Pro I’m changing a bit it doesn’t lower to the plate which is right under it goes to the right and forward I had sent you a link to the set up from your program if you can help me out please I’d appreciate it
https://drive.google.com/file/d/1574NgmJ_yrlw65FKZTxHcB_T-mIXxSSq/view?usp=drivesdk
I will have an update to the Triquetra Tool Box published shortly that should resolve the issue you are having when trying to zero just the Z axis. As soon as it is published you should get a notification when you open the Triquetra Tool Box. If you don’t see one then check the website for an update and get it that way.
After the Tool Box update is installed you will need to generate a new zeroing script. If you still have an issue after that let me know.
THE UPDATE FOR THE TRIQUETRA TOOL BOX IS DELAYED DUE TO A CODE SIGNING CERTIFICATE ERROR. I WILL GET IT PUBLISHED AS SOON AS I GET IT RESOLVED THROUGH TECH SUPPORT.
Charley Thomas
Triquetra CNC
Are you still around making these awesome tools?
You will probably need to pm [CharleyThomas] i have not seen him around for a while.
Just a FYI; Clicking on his name and going to his profile the info in there actually shows a users last login and his indicates that his last login to the forum was Jan 4th 2022
Yes Sir,
I am still making Triquetra Touch Plate and updating the combability list on a regular basis.
I won’t even turn on my machine unless i have the block ready to go…
Now that’s w hat I’m talkin’ 'bout!! Not to mention the list of compatible controllers just has a new entry. If your using UCCNC then I have a simplified solution. Automatic three axis zeroing without having to fill out a slew of complicated screen information. Click one button, answer some simple questions like what is your bit diameter and which of the available 6 methods of zeroing do you want to do? Actually there are 12 if you count each of the six being able to zero to your waste board or the top of your material. Then watch then magic!!
Oh, by the way, guess who has NOT increased their prices like just about everyone else. Triquetra CNC that’s who. Not to mention there is still an Inventables discount available to anyone on the Inventables forum.
This forum is where Triquetra CNC was born. This is where I became a Newbie and the people on the forum provided answers to my questions when I couldn’t find then anywhere else. I haven’t forgotten where I came from and the friends I made along the way… all here on this forum.
Charley Thomas
www.triquetracnc.com
