This part looks as if it a small 3mm clamp that connects the side board to the main assembly. Can’t find it for sale and can’t find the drawing. Can anybody help?
When I put mine together the part looked to be the exact same as 25293-05 https://www.inventables.com/technologies/extrusion-brackets-double-slot
That is where I would check as I see no difference between them. perhaps someone from inventables can verify.
Thanks, it is 3mm aluminum?
I measured mine without taking them off and they measure 2 mm thick by 20mm wide on both sides and can not get a good measurement on the length but it somewhere between 40 and 50 mm.
thanks alot
Looks like the length is 50 according to this drawing A Fond Farewell to GrabCAD Workbench - GrabCAD Blog
But the part in the store is gives a length at 34mm, so it appears it isn’t the same part.
