Hi, some one can help me? i will like to carve some fishes is there any metod i can use to do it from images?
As a simple test, I took your image, went and google searched: “jpg to svg”, and used the site convertio.
It converted the image to svg, downloaded, and I put that image in to easel.
Now, it made a very rough image, and when selecting a 1/32 bit, it did look “ok” when i set it to engrave at 1/2".
If you’re wanting something more detailed (with the actual curvature of the fish), you’d need to find a high quality 3d model of the fish you’re wanting.
Easel does not do 3D carving. The carving we normally do are 2.5D (obviously we produce 3D objects but the paths are rally a 2d planar cut). You’d need a tool like v-carve to carve a true 3D object (or a cad/cam package like fusion360) which can generate those paths.
Here is a 3D fish model for v-carve
