Is there a way to rotate the image to be carved without rotating the work piece?
One file I am looking at would fit well on a smaller board if the board stayed put while changing the angle of the image.
I have been experimenting with putting the board on an angle and setting up a false zero point at the front left with a taped down block that I can use to probe. Trouble is I have to let the CNC carve air over the lake or ocean, for several hours until it gets to the workpiece.
@Ken4 Thanks for the answer.
Select all does not give a handle. The STL handler allows you to rotate the image, but it also rotates the board I want to carve. Does not reposition the carve on the board.
Guess I am gonna have to learn to use a mesh handler.
@Ken4
Thank you thank you.
The key is locking X & Y then rotating the image, then you can center to the material and size the material to suit.
Brilliant.
