3d carves wont load
So i am trying to run a 3d file i have easl pro. The file comes up in easel but it wont load to the machine it either just sets on the loading screen or it sometimes goes to a error screen. I have tried multiple small 3d files same result. Does the same thing when i just click compile Any ideas
seems to be too large of a file.
you can reduce the file here > https://myminifactory.github.io/Fast-Quadric-Mesh-Simplification/ <
just remember the smaller you make the les quality you make it.
Most likely your settings are making the calculation too difficulty for your pc to process.
Can you share the project?
Hello Michael, I am having the same issue for all 3d projects I have loaded. Was you able to figure out the issue?
