The X-Carve page has this example:
"Precise 3D carving technology
Paired with Easel, X-Carve lets you carve with incredible detail and complex curves in wood, plastic, metal, and more."
Can somebody please explain the file type used and steps in Easel to produce this sample?
I have a fair bit of 3D modeling experience, but nowhere do I find a way to import 3D object files into Easel for carving.
This sort of carving was first done in a 3d application then sent to easel as gcode.
easel will not carve 3d models directly.
I agree Inventables that is a little misleading
“Our free Easel software makes 3D carving accessible to everyone”
P.S. only if you acquire and learn how to use a much more complicated cad program than easel
the statement is not false its just misleading
this is as close as you get to 3d carving in easel aka 2.5d
- Create an SVG in any program you want, either directly, or indirectly
- Import that SVG into Easel. Shades of grey are imported as different depths. 0 is no cut and 255 is full cut.
Try importing this SVG into Easel to see what I mean. So that shape can be cut by Easel without just importing GCode. I admit though, that directly creating that shape in Easel would be a PITA, and it would be easier in other programs and importing the SVG into Easel.
The above file is a 256 shades of grey
The way I understand 3d carving is that any time the x, y, and z axis are in interpolated motion together
you have 3d carving
I would be interested to see how that 255 grey scale deal comes out I know like in v-carve it uses grey scale to generate gcode for 3d carvings but it also as 4th axis support
that being said you could still produce the same result as the statue if you double side machined a piece
