It looks like Easel Automatic settings defaults the depth per pass to 0.0032". At the same time, Easel gives a warning about the depth being under 0.1" per pass.
With it being a 3d carve, does the Depth need to be so shallow? I know I might have to do some test cuts, but wanted to get a good starting point.
This point is interesting as the depth per pass in mm is not the same (0.7mm = 0.028"), around ten times greater. In my 3d relief models with lots of deep and wide valleys I prefere normally to stick to this 0.7mm (=quarter of my bit size) or increase to 1.35mm (almost half of the bit size). But this is a consensus between having
0.7mm => more roughing passes but less to be removed by the finishing pass and thus better finish quality on my point of view
1.35mm => less roughing passes but more material to be removed by the finishing pass in some places
As summary Iām a bit surprised by this 10 times factor between the default settings in the inch or mm worlds
