3d models carving with xcarve
Carving tilt in xcarve 500-500is challenging because it need to fit the zero when carving two File T1and T2
I have some problems in z steps
So the first file not the same as second file as shown
Any suggestions thanks
Check to be sure the waste board is perpendicular to the x axis. Looks like the front is a bit higher than the back so when you move it forward to start the second file it’s a bit high.
