3D STL file from photo
Is it possible to create an STL file from a photo? Suggestions on where to look and reliable sources appreciated. Using Easel Pro w/ Yorahome Mandril machine. Thanks in advance for your help.
Tom Shepherd
Youd need to use a 3d modeling software like Zbrush to create a 3d model based off of the photo… . . .carveco maker plus and aspire can also be used for this process
This looked interesting
it is web based and tries to help you make a 3D model from a single image. This is not photogrammetry. It just tries to give shape to images with a known outline.
You can also look at some of the lithophane software, but that is not really a solid shape of your original photo.
