can i buy a file from etsy. a 3d stl file and cut it on easel pro. i dont understand all this language
You can buy it but if you don’t have a program like vetrics vcarve to size it and set up your tool paths you can not use it. Your xcarve can cut it but you will need to generate the gcode in another program then import it into easel to run it. Hope this makes since.
Easel do not accept STL-files, you need to use a different program in order to generate a gcode-file that Easel will accept to import.
Different programs like Fusion360, MeshCAM, Vectrics and others are required.
Take a look at Kiri:moto. Another alternative to other software mentioned in this thread.
