HI there, I own a 1000mm xcarve, the things is I wish I could make it bigger, big enough to cut in a 4by8 DMF sheet, the thing is that the main concern I’ve is regarding is in x-axis because there are no Wide MakerSlide larger than 1000mm, so any of you have attempted to make that larger??
I’ve thought that if I do weld the pieces together might work, but I am not that sure because it is aluminum though.
If someone has been able to do so I would love to hear about that, or if there is a way to having a better gantry within a cheap option that will be wonderful because.
