Tiling on a 1000mm can be done, was a bit challenging to get the file setup correctly. I rotated each panel so the X/Y was always in the lower left corner of the machine. 40" x 44" Just needs some clear coat and will be done. Keeping my fingers crossed the clear coat goes on well as I have had issues in the past that it orange peels on me. I rotated the ring for the edge so they joints did not overlap. FYI painting acrylic paints over gloss black SUCKS!
Looks good Steve. Looks like you put a lot of time into this one.
Another amazing job! Thanks for sharing and pushing the standard higher.
How did you join all of the pieces together once you were complete?
the last picture shows the back side, crown staples and glue
