750mm Vs. 1000mm
Hello,
is there any difference between these two machines besides the size???
Pros and cons
I read that the X axis rod can sag or bent when in the middle of a job. If this is true is there an upgraded rail to eliminate this issue.
I want to get the 1000mm so if there is no difference besides the size that would be great.
Thanks
Where’d you read that? The new single piece X axis shouldn’t sag.
Nope.
Size is the only difference I believe. With the updated makerslide I believe any “sag” or flex has been elimanted. I own the 1000mm version with the newer X axis and have never had any problems.
when you say new X axis you are refering to having the 2015 version and upgrading to the 2017 ??
Sorry dont know anything about these machines yet
I bought mine at the end of 2016 with the upgraded x controller and the bigger x axis gantry. All the x carves come with this now.
I didn’t do any upgrades, it came that way.
perfect thanks for your help
Get the largest size that you have room for.
Going to that detail, the 750 mm uses 1/2” MDF spoilboard where the 1000 mm uses 3/4” MDF.
https://www.inventables.com/technologies/waste-board-with-threaded-inserts
Is the waste board and the spoil board the same thing?
Yes.
Are there other places to buy the x carve or just on inventables??
The Xcarve is an Inventables product. They are the source.
If you are in the UK you can buy them from a company called RoboSavvy (sp?). A distributor.
Far From it… Chicago IL USA
You can pick one up locally in Chicago.
ya I just noticed they are located locally.
trying to find a new 1000mm with a couple add ons for under $2,000
I bought mine with every add on except the side board for $16 and change. should be easily doable
A fully loaded 1000mm is $1671 with free shipping right now. You can add bits and material and still be under $2k
X-Carve 1000mm Rail Kit
X-Carve
X-Carve Core Components
X-Carve 110V DeWalt 611 Spindle and Mount
X-Carve X-Controller Kit
X-Carve NEMA 23 1000mm Motor Kit
X-Carve 1000mm Waste Board Kit
X-Carve 1000mm Drag Chain Kit
X-Carve Z-Probe
X-Carve Dust Control System
1/8" Precision Collet Kit for DeWalt 611
X-Carve Toolkit
X-Carve End Mill Starter Set
X-Carve Bit Set for Wood and Plastic
Starter Material Bundle
After IL taxes my total cost to $1890 with free shipping
