Hey everyone,
I ran into scaling issues when trying to import an SVG that I created in Illustrator 2020 (v24.0.1) into Easel.
I looked through the forums and found a lot of helpful posts, but none of them really resolved my issue.
So, I poked around with the settings and managed to get my SVG imported at the correct scale without needing to edit the svg’s code. I didn’t see this particular solution in the forums (maybe it’s there but I didn’t find it) so I thought I’d share.
The solution in my case was to remove the responsive setting when exporting my SVG.
Once I did this the SVG imported at the right scale.
And it’s specifically this setting. The minify setting has no affect on the size.
Here’s a video where I walk through the process of exporting -> importing with the settings that didn’t work and then the settings that did.
Fixing scaling issue from Chris Schmitz on Vimeo.
I hope this is helpful!
