Hi
Is there a way to label carve pieces in Easel?
So That, a person could put - “Bottom right” or “Left Side” for instance not carved on the pieces, but labeled on the screen for keeping track, much like a blueprint.
thanks for your advice.
Martin
The workpieces let you add notes.
Alternatively, you can add some text to your design, resize it to fit where you want it to go outside of the design area (on the blue area), and set the depth of the cut for the text to Zero. Easel will ignore the Zero-Depth letters when the GCode is produced.
Here is how it might look for you.
{:0)
Brandon Parker
Great Idea!
