Good Evening,
I’m trying to add an image on to the top of the stripes of flag. How do I do that with out the strips cutting through?
Stay Safe!
Good Evening,
Stay Safe!
I am not real sure but i think you could take the image and put it where you want it. Set it to 0 cut should turn white. Then take the same image and put on top of it and set to the depth of cut you want. May be the long way around but i think it will work.
Can you share the project?
{:0)
Brandon Parker
Use the offsetter app to create a background of your image and set that to zero depth behind your image but on top of your stripes
thank you
