Adding drill bits to the Easel bits dropdown menu
Hi, I’m just starting to use X-Carve and need help with drilling holes. I’d like to use drill bits instead of end mills.
Is there a way to add drill bits instead of end mills to the Easel bits dropdown menu?
Thanks!
Easel does not support drilling.
You can do operations that mimic drilling, but ChrisRice is correct.
Thank you both for the replies.
Michael, could you please post some instructions as to mimicking drilling in Easel?
For 3mm holes use for instance a 2mm end mill.
Or use a 3rd party software / app for genreating g-code:
Don’t use a drill bit with this technique.
