Adding fonts
Is there a old English font in Easel text or can it added. Thanks
Thank you …
Much easier to adjust font in inkscape too
When you design text based stuff in Inkscape, make sure to select all and Ctrl+Shift+C to convert it to paths after you finish your design but before you save to svg. Easel doesn’t like imported text, but it doesn’t mind imported object paths.
Thanks
Thank you .
I have the same question did you ever get an answer? cannot find it here
Easel have a limited fonts available, there are some add-ons which require Pro feature.
Outside of that you can not add fonts in Easel.
The simpler way is to use either a different program like Paint / Photoshop / Inkscape which have access to all fonts installed on your computer, and export this (as SVG if allowed) and import this into Easel for finalization/carving.
