I can/t seem to adjust nod what is the procedure. I tries to shim the router without success, is there an easier way? my front to back is 1/16 to 3/32 out. Thank you
Can you rotate the entire X rail? Use any play in the holes in the end plates.
Thank you, yes I loosened the 4 screws and tried to turn the x rail. no real help
Are there end plates anodized? Use a round file or drill bit to remove some anodizing. That will give you more play. I think it’s that or shim.
