Alarm: Homing fail. Y axe doesn't moves
Hi everyone!
When I execute the homing sequence with Arduino IDE ($H), Z axe moves correctly and the limit switch works. Then X axe moves also correctly and the limit switch works fine, but then, the Y axe moves a little (a few millimeters) and then it stop and the IDE Monitor Serie shows “ALARM: Homing fail”. Anyone can help me, please?:sweat_smile:
The Grbl settings are:
Grbl 1.0c [’$’ for help]
[’$H’|’$X’ to unlock]
$0=10 (step pulse, usec)
$3=3 (dir port invert mask:00000011)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=1 (homing cycle, bool)
$30=1. (rpm max)
$31=0. (rpm min)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=188.976 (z, step/mm)
$130=790.000 (x max travel, mm)
$131=790.000 (y max travel, mm)
Did you check your wiring connections for that axis, make sure everything is wired for NO, connected properly to the Arduino etc… it’s easy to flip the NO \ NC connections on those switches.
sounds like bad wiring connection or bad switch. but most likely the wiring
Yes, I have checked all connections and everything is ok. It make me crazy…:sob:
You can use this information to determine what grbl sees when the homing switches are pressed.
Since you are using version 1.0c you will not see LIM label, but you will see PINS: in the status report.
Thanks Larry! When I use the status immediate command (?) the IDE report me:
Alarm,MPos:1.000,1.000,-1.000,WPos:1.000,1.000,-1.000
ok
I am doing something wrong? :disappointed_relieved:
You need to change $10=19
Just I change it, but still does not work…
Interesting. Are you using the X-controller?
No
Here’s what I get when I do the ? command:
Idle,MPos:0.000,0.000,0.000,WPos:0.000,0.000,0.000,Pin:000||
ok
Try $10=255
Just I change it, but still does not work… Now the ? command report me:
Alarm,MPos:1.000,1.000,-1.000,WPos:1.000,1.000,-1.000,Buf:0,RX:1,Pin:010|0|0000
Yes, it did. The Pin:010 says that your Y axis homing switch is tripped.
But when I do the $H command still report me “Homing fail”. What can I do now?
You have to determine why your Y axis switch is not working. It is acting like a Normally Closed switch. It could be a wiring error, it could be a defective switch, it could be a defective Arduino.
Try this
Press the Y axis homing switch with your finger and then issue the ? command while you are holding the switch closed.
Post the ? command output here.
While I hold down the Y limit switch, I introduce the ? command and report me the same:
Sorry, now report me:
Alarm,MPos:1.000,1.000,-1.000,WPos:1.000,1.000,-1.000,Buf:0,RX:1,Pin:011|0|0000
Most likely is a wiring error.
Can you post a picture of the connector that contains the homing switch wires, that plugs into the gShield?
It just occurred to me that you most likely held down the X axis switch and not the Y axis.
The X axis moves left and right. The Y axis moves forward and back.
So, the Y axis homing switch is on the left at the near end of the Makerslide, not on the gantry.
