So, did you do the switch test on the X or the Y axis?
I have to do some work that will take me about 1 hour. We can continue later, or at another time if you will not be working on your machine for another hour or so.
Connector looks good.
Ok Larry! Thanks for the help! Iâll keep trying and testing all.
@HerminioGarciaSalgad
Have you made any progress on this issue?
Now only works de Z axe⌠I have checked all connections and wires, I have restarted the Grbl and when I do the $H command only works ZâŚ
$0=10 (step pulse, usec)
$3=3 (dir port invert mask:00000011)
$6=0 (probe pin invert, bool)
$10=225 (status report mask:11100001)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=1 (homing cycle, bool)
$30=1. (rpm max)
$31=0. (rpm min)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=188.976 (z, step/mm)
$130=790.000 (x max travel, mm)
$131=790.000 (y max travel, mm)
Alarm,MPos:1.000,1.000,-1.000,Pin:|0|0000
The report status mask changed. Change it back to $10=255 for now.
Letâs test each switch by itself.
The order of the axes in the report is Pin:ZYX (you can ignore the other numbers for now).
With the power off, move the spindle away from the homing switches by hand.
You donât need the 24 volt power supply on for these tests. You do need to have the USB cable plugged into the Arduino.
Until we can get a status report with Pin:000 your homing sequence is guaranteed to fail.
So, do the setup above and post the output from the status report command ?
Donât know where you are, so if you donât have time to work on it we can do it later.
Iâm from Spain, Itâs midnight but it doesnât matter, hahahaha! I have tested the homing switches by hand with the power off. I hope I have done well. When I have finished, I do ? command and report me:
Thanks for your help and patience!
Glad to help.
Change $10=255 and do the command again.
Sorry, I had forgotten.
Alarm,MPos:1.000,1.000,-1.000,WPos:1.000,1.000,-1.000,Buf:0,RX:1,Pin:011|0|0000
Ok, so it looks like X and Y are tripped.
unplug the connector that has the homing switch wires in it from the gShield and do the ? command again. Post the results.
The same results:
Well, weâre getting somewhere. Thatâs a problem. Do you know how to flash the grbl firmware into the Arduino?
I think yes. With the IDE in examples>grbl>grblUpload, isnât it?
Yes, make sure you have the correct grbl library loaded into your Arduino IDE and re-flash the Arduino.
Ok! Re-flashed! And now?
Check the $$ output. Post it here. Change $10=255
with the connector still not plugged in, do the ? command and post the results.
$10=255 (status report mask:11111111)
$30=1. (rpm max)
$31=0. (rpm min)
Idle,MPos:0.000,0.000,0.000,WPos:0.000,0.000,0.000,Buf:0,RX:1,Pin:011|0|0000
One more thing to try. Make sure that the gShield is firmly mated to the Arduino. Sometimes they can get loose.
