Hello, I have looked at other threads to find my answer but cannot solve this issue. I click on add bits and add a new ballnose bit, if I try to select one for my job, it doesn’t appear. Only end mills and v bits appear.
Correct; Bits Entered as BALL bits can only be used for 3d finishing.
You could lie and enter it as an endmill to be able to use a ball bit in the 2.5D workspace, but the stepover will also need adjusted and the preview won’t preview the radius either…
