@AngusMcleod Those screw holes match up perfectly, I ordered those the other day to replace the one I crashed into on the Z axis. $0.48 each for replacements when I kill more and lots of spares.
Did you read my post for protecting Z switch. ?
I did, that’s next step. I read it after I broke the first one in Easel.
They are ok. That is exactly the switch I used on my 500mm
How has this been working for you so far?
Do you have a suggestion that worked well for you to protect the X and Y limits?
Thanks!
I only used for Z axis, that’s the only one you can easily break. But if you can find a way to limit other axises same way, it works.
I cut a small piece of 1"x1"x1/16" aluminum angle 5/8" long * mounted into wheel under the switch
to provide a good contact surface for the Z-Axis switch to hit. I did this because my switch was
slightly damaged before I got my GRBL settings correct.
( I use normally CLOSED to eliminate RFI/noise ).
Thanks for the tips guys. I appreciate the feedback and suggestions.
Hot glue. Seriously. Works just fine for me, and if you crash, the glue fails before the switch does.
This post was from last year, inventables sent me another plate. Thanks for the suggestion though
