Aluminum Carve
Can I carve Aluminum 040? If so, what bits are recommended for my X-Carve Pro? Thanks for any help!
What’s the 040? Is that the thickness?
Most aluminum you’ll find is easily machinable. The pro should have no issues.
Do you know the type of aluminum?
I figured it out. .040”. That’s the thickness. I called Inventables support and they helped.
8928A141
I use these for brass letters cutting through sheet brass 1/8 thick, high speed low feed
