I have resently bought an x controller so now I have a arduino,gshield and powersupply to spare…so now I wonder what to do with this,a shame to just let it lay around and in the end most likely be thrown in the bin
For a long time I have been wanting to add a 4th axis,but as many of us know this is not possible with the standard electronics where as there is no support for more then 3 axis,bummer.
So now i wonder is there any chance to hook the x controller and the old electronics together in a way to make way for the fourth axis ??
It is probably doable, people have done it with just the Gshield by itself. The problem is GRBL doesn’t have a parameter for deg per step. So you have to manually calculate it for each project. (there are a couple of threads that address this) TinyG (the GShileds big brother) does.
I have so many parts left over for various upgrades I can almost rebuild a second machine. So I have been thinking about possible uses for leftover parts too.
Maybe a dedicated laser cutter?
Yeah been thinking about a dedicated laser I guess this is the most doable thing to do with it.I already have the jtech laser so might get the rest of the parts oh these decisions
This was talked about before.
If you do disconnect the y axis and use it there are some calculations you have to do to convert liner motion to radial motion.
