Has anyone tried using a laser with your X-Carve? If so, what type and what were your results? Do you like it? so on and so fourth.
Thanks
Laser cutting is not listed by default in the forum but if you click on the all categories on the upper left corner you will see the laser cutting category listed as well as some others. you might want to check them out.
