Arduino file
I gotten EASEL to work on my initial startup and never again since. I was using UGCS and have since switched to PicSender. It has a feature to view the “Grbl” (which I have no real good understand of) and have it displayed below. I have seen post listing commands that I don’t see in the file such as “$30” I re-flashed the Arduino and the file is what I was let with. Am I missing something and if so how do I repair it
$0=10 (step pulse, usec)
$3=3 (dir port invert mask:00000011)
$6=0 (probe pin invert, bool)
$10=19 (status report mask:00010011)
$12=0.002 (arc tolerance, mm)
$13=1 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=188.947 (z, step/mm)
$130=290.000 (x max travel, mm)
$131=290.000 (y max travel, mm)
Here are descriptions of each of the grbl 9 settings.
The $30= setting is in grbl firmware that is installed with the X-Controller.
If you have Xcontroller it comes with GRBL v1.0c maybe you can get from Inventables. Its still in beta.
