Aspire v- bit carving / depths
Newbie to Aspire, and trying to cut the SW aztec calendar.
No matter how i set the depth pass on the bit, it wants to plunge pretty deep and cut which makes my machine groan.
I’ve researched the topic a bit and am seeing two different opinions: depth per pass has no affect on v-bit toolpaths in aspire, or the opposite, that setting a per pass depth should work.
also if i dont set a flat depth i get a warning that my toolpath will cut through the material (1/2" MDF).
Do I have my bits set up wrong (i dont think . they are) , or is it true you cannot set multiple passes for a v-bit in Aspire?
Appreciate someone giving this noob a little guidance. Thanks.
You need to set a flat area depth, and add a clearing bit.
