I am wondering if there is any way to use an ATC (automatic tool changer) with a modified X-Carve. The hardware will work fine. A 2.2kw water cooled spindle with ATC. I am wondering about the post processor. Does anyone know if there is a way to do it?
Typically, your CAM program (Aspire, I’m guessing) will just need to prior an M6 tool change command. From there, it’s up to your sender to interpret that command and run an appropriate macro for your hardware.
When you say the hardware will work, are you sure your xcarve controller has the appropriate outputs to control the ATC?
Grbl is somewhat limited, but depending on the hardware, it’s possible.
No, I should clarify. When I say hardware I was only referring to the spindle and rails etc. The X-controller and software that are the question.
What ATC are you using? Can your spindle spin backwards? What’s your lowest rpm? ATCs with grbl are limited and will not be plug n play. Your sender will have to do most of the work with macros.
I don’t know about the specifics. It’s a 2.2kw 220v water cooled VFD spindle. Currently I export g-code from Ascend and use the “import g-code” in Easel. I don’t totally understand where the spindle change would come into play. Is there a setup in which I can make an ATC work or do I need a different control board or something?
