Attaching NEMA 17 Motor to X Carriage
I received my X-Carve kit today and began assembly late this evening. Yay, me!
One tip I can offer for attaching the NEMA 17 Motor to the X Carriage. Put the long end of the correct hex driver into the top of the Socket Head Cap Screw and use some clear tap around where they join to hold them together. That way, you can easily insert the screw throught the back hole and find the hole in front that the screw needs to go in. Once secure, backing the hex driver out will pull the tape from the screw.
Hope that helps someone!
-Brad
