Does anyone (propably from Europe) upgraded their 230V spindle with automatic spindle control?
The only solutions I found in this forum and on YouTube was 110V with a IOT relay. The relay is unavaiable since month, so my idea to import a 110V router and use a 230V-110V converter doesn work.
Best regards
Maik
You can use a SSR solid state relay and that is what is inside if the IOT anyway…, the iot is just in a pretty package.
What Seth said.
That is the way I control my router and vacuum, separate relays for each.
Thank you very much! But I’m not sure if I have the skills to get this running. The IOT looks pretty much like plug and play. Perfect for a electronic noob like me.
Maybe I find a way on YouTube.
Thanks guys!
