I recently moved the Xcarve power supply to a enclosed cabinet . Photographed all components and wiring prior to disassembly. Ran setup and found the Automatic spindle control coming on prior to the Turn on Spindle command box. When I engage the turn Spindle on box it shuts off. I have yet to figure out what i have done to cause this or how to correct it. Manual controls and test carve works perfectly with the exception of the Auto Spindle control.
What spindle?
How do you have it wired?
Did you accidentally plug it into the auto off socket? I know I did that once.
Darrin1200, thanks! That is exactly what I did. Had a senior moment. Thanks for the reply.
Is this feature still available? seems to have disappeared from the new machine setup screens
Yep. Just need to select a different spindle type from machine>edit machine
You are the man Seth!!! Thanks
