Axis direction reversed
z axis ok
y and x axis both reversed left button goes right, etc
it did work fine ,I didnt change anything ,
so i tried new usb cable then new gshield and uno board ,wired the same ,still backwards
The machine setup wizard in Easel has a check box to reverse the direction of the axis.
(It resets the direction flag in your controller)
It’s reversed in UGS also ,
And set to inches setting it moves about 4 inches when it should only move 1
I decided to start from scratch
Tried clearing EPROM ,re uploading GRBL . Nothing works
I even tried the x loader and hex file ,still reversed
It wasn’t like this before ,
I spend 3 hours trying to connect to easel ,only to have this
Wiring is still the same ,
Should all 3 green lights be on all the time ?
Mine only come on when it’s moving .
It is normal for the green LEDs to turn on and off as you operate the X-carve.
Post your grbl parameters here (output from the grbl $$ command).
I got nothing ,USB port busy
USB port in the laptop seems too loose so,
I’m going to start from scratch and try another USB port and reinstall the arduino drivers .
Using win 7 , is anyone using Windows 10 for this ?
I really don’t want to do that ,I’m a Linux guy but I couldn’t get easel to work on Linux
Did you run the Easel setup? It will fix this for you. The fix will apply to using UGS also.
Which version of Easel Local are you running? version 0.2.3?
If The USB port is busy and your not “connected” then restart Windows,
regards Neal
I do not know if this has anything to do with your problem but if I leave the Xcarve USB plugged into my laptop, if I restart the computer my computer won’t boot up or the machine can not be found. I have to wait till the laptop is booted up with easel ready and looking for the machine. Only then do I plug in the USB and power up the machine. For some reason, I am unable to always leave the USB constantly plugged in. Otherwise Easel can not find the machine.
Don’t know why this is happening, but atleast for my issue I have found a work around. Not the most convenient process but it works.
Don’t know if this is anything like your situation but thought I would share just in case.
Seems fine now ,on other port ,
I think the USB port was bad ,
But it’s weird how a bad port can cause it to react that way
Is the motor still reversed or did you get that fixed as well?
↑ this. Depending how you wired the stepper motors, some bits in the Grbl $3 register may need to be flipped. Easel setup will test the axes and program the register to fix the axis directions if any of them are backwards.
It was a bad USB port on my laptop
Also I’ve learned to boot laptop first then power on
The carve ,then start UGS .
Works great ,I’m really impressed with the accuracy of x carve ,
Once I got the belts to stay tight
