Attempted to use Chilpeppr on Saturday and it was grief, so did first carve with Easel. Made an error with the outline/fill for the letters, but everything seems to be ok with the unit itself.
Played around with Chilipeppr for a while, read some threads and asked some questions and got it to work. In the meantime, as mentioned pulled apart wiring and redid it. Am not 100% happy with it, and will have another go when I get some 4 core cable - can’t find any here to use for the motor cabling.
Have to order some more bits now and spend some time in VCarve.
So that’s it for me for now as far as this build is concerned. Looking forward to hear from you when you start yours.
This is like buying 4 tires before a Car. Good luck. Keep your table as much strong and square as possible. Weak table changing level so quick and causing problems.
Make sure you have all the bits and pieces… It really sucks to be on a roll assembling the machine and discover that some small, presumably very important part is missing.
I hope you have all V-wheels, though… Had that WTF moment as I picked what was supposed to be the last V-wheel from the bag and discovered it was not a V-wheel at all but one extra wheel for the belts.
