You can use the super gradient generator to make the contour close to that, it would take some sanding to get it perfect though… because super gradient makes a bunch of steps, you can increase the step count to do less sanding. But then the carve will take longer…
Well easel will only show what an endmill looks like, but I would set easel to an endmill and use the same size ball bit instead, that will reduce the step sizes a little bit…
I’ve actually made those type of stools before I had a cnc,… I used a template and cut strips to rough size on the band saw, and then using a pretty perfectly contoured piece by sanding to the printed template edge, I used the router table to contour all of the rest to match perfectly, and then edge glued my strips together to make the stool top… would have been a lot easier on the CNC though
