Bar Top Epoxy Inlay
Here is a epoxy resin inlay project I just recently completed for a client. The project started out with an old pine workbench the client wanted to use for a rolling bar. Using traditional handtools and methods I flattened out the top in preparation for the inlay carve. I coated the inside of the carve with resin and waited for the it to cure before pouring my final inlay. I poured a bit to much resin so it took a bit of work to get the inlay flat to the table again but it worked out well. Stained the wood darker per the client request which came out pretty cool.
Awesome job!
fantastic
Thanks Gents!
Way to go! This looks amazing. Well done.
Thank you sir!
