Beginning of my CNC project using wide MakerSlide
Just a sneak peek at my idea of using wide MakerSlide for both the x and y axis. (Video)
Hi, what is the distance between the 2 Y rails now? Did you cut your own side plates? I don’t think I saw them in grey before.
The steel plates are all cut from some 1/8" scrap sheet metal I had. When I’m finished building I plan to take it apart and powder coat. All of the wide MakerSlide is 1000mm.
Making the plates.
Started with scrap.
Glued templates to the plates.
Done.
Screw drive?
Yes, I have 8mm lead screws for x, y, and z and plan to have two y motors.
I see, nice work on the plates.
About the distance between the Y axis, sorry if I was not clear, i get that the wide makerslides are 1000 but what I wanted to know was the distance between the 2 rails. Actually, I am trying to figure out how long the base rails need to be, mine are the stock 1000mm and I don’t know if I 1200mm would be long enough mount the end plates.
Nice, been done by many of us already. Makes the x-carve nice and ridged, especially useful for the 1000mm.
here’s a thread of mine and some others
Brian
I got the 1500mm 20x20 rails to be sure I had room and will cut them down when I’m finished. I’ll take some measurements later when I get back to the shop and post.
