During the assembly is calls for a tension screw (25mm) to go through the end plate on the belt clip and the 8mm be hand tightened in the insertion nut. This is used to adjust tension on the belt. On the other end it only calls for the 8mm screw to be inserted the belt clip at the opposite end in the pre-assembly insertion nut and lightly tightened.
Can someone please explain why you wouldn’t secure the non-adjustable end with more than a “lightly tightened” 8mm screw in the belt clip to the pre-assembly insertion nut? Would this not make more sense and prevent the belt from potential unnecessary loosening? The instructions also do not show the end that does not require the 25mm tightening screw.
