I’m in the belting stage, and I can’t get the M5x8 screw in. I’ve tried to switch the 8 and the tension screw; but they keep getting caught on each other. Does anyone have any tips?
put the vertical screw in place first
Thank you, did that and had to muscle it down and kinda stripped the screw in the process. But should all work still
Can also bend the belt clip down just a little, tensioning up the screw will go back to its original flatness.
I found the simplest was was to put the vertical screw in place first and just barely tighten and then put in the second screw. You can then adjust and tighten as needed.
