Hi there,
I’m cuttin in aluminium and I’m doing that with a 1,5 mm bit at 0,5 mm per cut and at a cutspeed of 50 mm / minute. And that works fine. So far so good. Now I noticed that lifting the bit, going back to the start of the cut and lowering it again to the next cut layer takes about 40% of te time on average. The bit lifts 3-8 mm depending on how deep the cut is, and that takes a lot of time compared to the rest of the process…
Is there a way to make this more efficient? I.e less “mid-air” time and more cutting time?
Kind regards,
Tom…
