Bit for cutting through 1.5" stock
Which end mill do you recommend in 1/8" diameter for cutting through 1.5" thick material with the carvey? the included ones are too short
That’s going to be a difficult bit to find. With a thin bit like that the bit can start to flex the longer it gets.
What are you trying to accomplish?
Longest I know of:
http://www.ebay.com/itm/1-8-1250-2-FLUTE-LONG-FLUTE-1-125-CARBIDE-ENDMILLS-FOR-WOOD-OR-PLASTIC/151859867020?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D555012%26algo%3DPW.MBE%26ao%3D2%26asc%3D36462%26meid%3De3b660ecdbdf41b1a83984bbb19e3474%26pid%3D100010%26rk%3D2%26rkt%3D24%26mehot%3Dag%26sd%3D151652883315
search ebay for 1/8 endmill extra long. they will cost around $10-15 for a 3 inch they are easy to find but my issue with them was material removal from the cut. if you get one go slow or SNAP! I use the extra long 1/4in straight flute router bit.
just for the final cut through to make some toy cars. rather than taking thinner stock and gluing it together
for the 1/4" straight router bit, do i need to have a full 1.5" cutting length, or can i use one with a 1" cutting length and plunge it just a little farther?
better than pausing operations to clean out cut
If you take depth cuts, you don’t need full cutting length BUT you do need to grind the shank a bit smaller for clearance, past the cutting edge, or it will rub and burn your nice finished edge.
Depends on what you are making…
http://www.sears.com/craftsman-1-4-in-straight-router-bit-2-1-2/p-00928641000P
